I have used several of their encoders over the last few years, and have had no problems at all. I have two E6's, used for steering feedback, in my radio-controlled vehicle crashing system. So far, each one has survived 6 crashes. I've always found them great to deal with. Excellent tech support, too. I wouldn't hesitate to recommend them. They are not sealed, however. I would call them dust-tight. Check with their tech support, but I don't see any reason you couldn't seal the cover with some sealant. The cover also forms the shell for the connector, and that would be tricker to seal. Michael Rosenfield
Message: 4721 |
Date: 5/1/2012 |
Subject: Re: US Digital E5 Differential Encoder |
Thanks for the reply.....It looked like the plug area could be a problem. I may have to make supplementary covers, I guess.
Mike
--- In DynoMotion@yahoogroups.com, Michael Rosenfield <mrosenfield@...> wrote:
> I have used several of their encoders over the last few years, and have had no problems at all.I have two E6's, used for steering feedback, in my radio-controlled vehicle crashing system. So far, each one has survived 6 crashes.I've always found them great to deal with. Excellent tech support, too.I wouldn't hesitate to recommend them.They are not sealed, however. I would call them dust-tight. Check with their tech support, but I don't see any reason you couldn't seal the cover with some sealant. The cover also forms the shell for the connector, and that would be tricker to seal. Michael Rosenfield
> From: michaelniksch@...
> Date: Tue, 1 May 2012 13:27:15 +0000
> Subject: [DynoMotion] US Digital E5 Differential Encoder
> I'm looking at buying the US Digital E5 differential encoders.
> Does anyone have anything good or bad to say about these concerning their performance and reliability?
> Does anyone have a better recommendation (differential)?
> I have the Kflop and Snapamp.
> I was looking at the 500cpr units which would give me 30,000 counts per inch on my x and y, and 37,500 on my z. That is more than adequate for resolution.....but, is there any reason I might look for more or less counts based on anything else?
> Does anyone know if the E5 enclosures are reasonably moisture proof?
> This is for a mill that will be running flood, although the motors and encoders would not have any coolant allowed directly on them due to deflectors.
> Thanks
